just did a fault diagnosis code test on the bravo and got...
M
Michael
cylinder 4 issue..cant say exactly what it is as i left the readign at home
but cylinder 4 is causing a problem
now what do i do to rectify this..please help..
I had this problem a few weeks ago, it was the coil pack,try the leads first as they are cheaper! if no different probably be the coil pack i bought one off ebay 1/2 the price than fiat and a 2yr guarantee!!
good luck Jez.
ok here is the official fault reading
P0300 Ignition Failure (Generic)
P0304 Ignition Failure Cylinder 4
Could be plug lead or coil pack. Leads are cheaper so try them first. No harm in having new ones.
hi so is this nothing to do with an injector??
i think it might possibly be the coil pack..
cant see a repair guide for fitting in a new coil pack..anyone know>
Easy,held on with 4 torx/philips screws,and should be numbered 1234 so you put the leads in the correct places 5/10mins of a job!!!! ebay 40 odd quid guaranteed for 2 years.
