Number plate lights
Number plate lights
B
BRAVO_CT
Is it possible not to have the rear lights over the numberplate? Wanted to change the rear bumper, if the answer is that i need them can i use the bolts that hold the plate on with the little LED's in them?
Chris
Hopefully the above makes sense, should have read through it!
Chris
It is unlawful not to have rear number plate lights, it wont pass an MOT and you'd be liable to a fine if stopped.
As long as the number plate is lit it will be ok but I think you will need 2 lights to do it, maybe 1 in the middle will do, not sure on that one.
As above, it needs to be lit somehow. I believe if you use a pair of the led bolts this will be sufficient.
Gav
You don't need pants for the victory dance
my mot company put led bolts on the dont light up **** but they passed the mot haha
R
3
385
T
J
577
J
C
205
Craig Parker
C
P
2
294
Dark Lurker
