M Matt Guest Jul 26, 2006 #1 Does the steering wheel from the Fiat coupe fit a bravo if so is it a straight swap? Cheers matt
R Roberto Guest Jul 26, 2006 #2 The steering wheel in the HGT is a Coupe wheel, without the multi coloured leather, so yes, it should go straight on. Rob Marea Weekend 1.8 16v 115 ELX
A Anonymous Guest Jul 26, 2006 #4 "The steering wheel in the HGT is a Coupe wheel, without the multi coloured leather, so yes, it should go straight on." Incorrect. As far as i'm aware the only steering wheels that fit the Bravo are Brava/Marea/MK1 Punto.
R Roberto Guest Jul 26, 2006 #5 Yes, on closer inspection, the HGT wheel is "Coupe Style" but ever so slightly different (horn buttons on the edge of the coupe wheel) I'm sure it can be adpated though. Rob Marea Weekend 1.8 16v 115 ELX
A Anonymous Guest Jul 26, 2006 #6 The original question is, will it fit. Not does it look the same style. Fiat Coupe Wheel Bravo HGT Wheel Adapting a steering wheel? Eh? If it did fit then you'll have problems with connecting the airbag. Do a search this has already been answered before.
R Roberto Guest Jul 26, 2006 #9 What do you want, a gold medal, or a chest to pin it on ? Rob Marea Weekend 1.8 16v 115 ELX
