97 Brava 1.4s Wiper Motor ????????????
B
Babar Malik
Rear Wiper has died, no fuses seem to be blown. Rear high level brake light and rear washer work ok so i'm assuming its not the connection blocks on the back sill and tailgate? If its the motor could i check by just using a multimeter between the motor terminals to look for 12v when the switch is on? If it is the motor where's the best place to get a cheap new replacement?
It WILL be the motor. Try clening it up first. A few have had success doing this. Failing that - off to the scrap yard!
What exactly do you mean by 'cleaning'? Cleaning the contacts or stripping down the motor itself?
Try cleaning the contacts 1st - if that fails go for the stripping
you may,,,i repeat may be in luck! i might sell my rear wiper motor from my hgt, they will be exactly the same so dont worry about the different models....
I dont know how much it is worth... where abouts are you?
Paul R
Why do you want to sell your original motor, dont you like having a rear wiper?
well i am a bit strange....i dont like rear wipers, i think they are a waste! i never use mine and i think the back looks smoother with out them! I am probably only going to take it off anyway....
like i say i dont know what its worth, probably best if you call around you breakers, find out what the cheapest you can get them for and we can go from there! where abouts are you in the country?
Paul R
I'm in glasgow. Where you? A websiote listed an oem standard replacement for approx £80. I'll still to check with my local fiat dealer for an oe price.
I wouldnt wont that much! call a breakers! you will get them loads cheaper!
Glasgow however is not bloody close!!! i am near london!
So i will have to find out postage, unless you want a drive down?
Paul R
cool... my number is 07730575753 if you need to get hold of me!
Paul R
538
Dark Lurker
6K
David Slaney
J
673
jason
J
G
2
647
T
I
2
747
Dark Lurker
