Recommendation other than Pipercross BMC?
M
Mario
Is the BMC the one with optional samco hose do you know?
What is the recommended induction Kit other than BMC for money? Don't have an awful lot of money to spend at the mo.
Pipercross DO NOT MAKE the BMC filter, BMC make the BMC filter.
Pipercross make the Viper which is much better.
Re: Re: Recommendation other than Pipercross BMC?
BMC are very good well better than K&N but only if it is the CDA (carbon airbox).
I am puting one of the universal ones on my Focus tho you will have to order the samco hose seperate.
If you want I can try and locate the parts for the exact car what engine???
also is it just the straight hose or is it one to move the filter (mine is 80mm diamiter in an L shape that runs for 8")
Cheers Lew B
Re: Re: Re: Recommendation other than Pipercross BMC?
Lew, have you seen a BMC CDA?
Re: Re: Re: Re: Recommendation other than Pipercross BMC?
EJ has one fitted in his HLX. he's currently looking for a length of Samco hose to replace the crappy flexi pipe it comes with.
Evolution do a cheaper silicone hose and i'm buying some for the Corsa's custom induction kit.
Jay
Re: Re: Re: Re: Re: Recommendation other than Pipercross BMC?
The pipe BMC send is not worth anything, its dire.
Same goes for the build quality of the CDA filter, it sorta pushes together.
Re: Re: Re: Re: Re: Re: Recommendation other than Pipercross BMC?
I think the bmc is good for me as its produce less sund as my exhaust is already to loud, but over all im happy with it and its all base on your taste
Re: Re: Re: Re: Re: Re: Re: Recommendation other than Pipercross BMC?
I just object to paying so much for something that looks so cheap. At least the viper is spun aluminium.
J
1
379
Dark Lurker
P
7
1K
Paul Morrison
P
L
402
Lurk Darker
L
