Cheers for your help. Oil sounds the same, but it does smell like trans oil although thin. My dad on hol at the mo (nob) said when i went to birmingham and back non stop may have thinned iit a bit. could explain y it is leaking.
my leaks a bit more frequent, the small 2pound coin size pool is now a like te diam of a mug every morn.
Think iv found where its comming from, not sure yet, but where the drive shaft comes out, the cv joint? Are there any seals down there that could bust or does the oil just need changing?? im puzzled
Guna check the transmission oil level later tonight and just keep topping up until i know the prob for sure.
Any suggestions on whats needed from this though would be brilliant. Ant
