Technical Front wheel arch line -splash guard- problem
vitaqo
I have bought a broken Bravo since 5 months. The car was good, but every hole the aftermarket front wheel arch line (splash guard) touch the tyre. After the problem i bought an aftermarket splash guard, but the problem is not solved. Maybe i should buy an original? The car was damaged on the front right side.
I think you should first try the local Hungarian forum.. you might get somebody willing to let you try their wheel arch so you can see if the original one touches.
I will buy a new original for 40Ł, but the question is, my front suspension are wrong? The settings are good (all is under the limit).
