Hello,
I'm a long-time "lurker" here on the forum and on ePer.
( Didn't bother to register so far, since I found everything on the spot ...)
So first of all thanks for the great service!! - Got already quite some infos from here.
The wheel bearing on my ducato are making trouble, so I'm just putting the parts numbers together (I will also replace the brake disc at this opp).
So why do I put this in the site forum?
Because I wanted (have it in the past, IIRC) to use the shopping cart functionailty of eper for this. Which is very nice because it gives you a rough price estimates and the part numbers all in one table, with which you can go shoppiung then.
However it doesn't work anymore! If you put something in the cart there is always an error message.
Any chance of fixing this?
cheers
cheers
