Technical plastic clip from the gear stick?
hisXLNC
Does anyone know what this is? I found it broken in 2 pieces under my gear gaiter. Could this be holding the gaiter to the gear stick maybe?
looks like a c..k ring :D but on serious note, these can easily be replaced just nip down your local breakers yard whip one off another punto, you might be lucky the guy in charge will let you have it for nothing. i always get this treatment from time to time :p
it holds the top of the leather gear gaiter to top of the stick,
turn the gear (leather) gaiter so its more or less inside out and click it back on,
its not broken they is meant to be like that,
Edit sorry didnt look at picture properly..it is broken,
Thanks a lot, the leather gaiter dropping drove me crazy... I will try it tomorrow!
edit..
just had another look at picture...its broken,
Superglue is worth atry.
=or also named crazy glue in some other parts of the world
id just use a cable tie, :)
edit..
Superglued it already, if it doesn't hold, I will try a cable tie (y)
thanks again!
