Technical Error With Punto Evo U1715
Gittins
Got a problem with a punto evo 2010 1.4 turbo 16v multiair
On the dash a message shows up with ESP unavailable and Hill hold unavailable
I scanned for codes on the engine and got back Error U1715 - Side Acceler./Yaw Node (NYL)
Does anyone understand this error? I have cleared it but ii returns
Sounds like the accelerometer that measures sideways acceleration/"g force" has packed up (or rather the CAN node that it sits in has got issues).
certainly a canbus related fault
@zanes seems to be pretty much on the money there.. judging by your description,
EDIT - looks like you've scanned the ABS - NOT the ENGINE..!! ; - }
charlie
Yeah it was the ABS I connected it, shows at the bottom of the picture, got mixed up
Where would I find the accelerometer or the can node?
I read also could be the YAW sensor?
They're possibly the same thing. I always thought that yaw sensors were gyros but I guess they could be an acclerometer too. I would have thought they'd all be packaged together in the ESP "can" that's under the bonnet.
Is there any pictures on the forum to show where abouts I need to look?
I also read that the YAW sensor is near the gear stick and handbrake? Not but I'm not sure how to remove this part to access to have a look
Still no idea about this
Is there a Haynes manual for the punto 2010?
Did you manage to find the yaw sensor ?
It has to be bolted on chassis, possibly the region you mentioned. But not sure.
Don't know any doc for the Evo. Perhaps can I find something on Grande Punto if you want.
Yes if you don't mine please
With pleasure ;)
After some search, I found on the Grande Punto the YAW sensor is behind the gear stick, under the cover of handbrake. I can't verify this on my car, because I don't have ESP.
To remove the handbrake cover, you have to pull on it. I start with the rear part, it's more easy to take it. Never removed it completely, not necessary to set the handbrake tensioner.
Procedure :
Hope this help
With pleasure ;)
Procedure :
Hope this help
Thanks for the info, gonna have a look at doing this tomorrow and see how I get on
With pleasure ;)
Procedure :
Hope this help
I can't seem to figure out how to remove the hand brake surround, is it screwed in somewhere?
No screw in my cars.
Official way (if it is more clear for you, for me not really... I pull and shake the cover, more at rear, until it comes) :
So it's not screwed on then and will just pull off? I want to make sure as I don't want to snap anything
Is there some sort of trick to this or do I just go ahead and pull at the cover from the back end first giving a shake from left to right?
Just pull off
I took a pic for you :
Hope this helps, keep us informed ;)
I tried and tried to wiggle and pull that part off but only managed to slightly put up one side but as soon as I let it go it pulls back together again
