maskedmagicians
- Joined
- Apr 7, 2014
- Messages
- 25
- Points
- 12
Have the following eror codes that will keep reoccuring...
Confirmed Trouble Codes
P0460: Fuel Level Sensor "A" Circuit (Powertrain, Generic)
P0571: Brake Switch "A" Circuit (Powertrain, Generic)
P0340: Camshaft Position Sensor "A" Circuit (Bank 1 or Single Sensor) (Powertrain, Generic)
Pending Trouble Codes
-none
Permanent Trouble Codes
-none
all of refer as far as im aware to a circuit malfunction...
so im wondering if there all wired i guess together, like on the d4 connector?
if anyone can point me in the right direction be most appreciated cheers
brake switch was constantly on at one point removed switch, pulled out plunger until it clicked and re fitted and works fine...
also gearbox/engine mount has excessive play and front flexi is blowing if this helps... got parts to fix this just havent had time to jack it up and fit at the moment cheers
-none
-none
