Technical Radio staying on in Doblo 2014
Ennisdoblo
Ive read that it's supposed to stay on for 20 mins after the ignition is turned off. I'm just wondering is there a way of changing this? Any help much appreciated.
Cheers for the reply, can't find an option for it anywhere on the head unit or in the obc menu. Maybe can't be changed
Still havn't got this sorted. And now the small back door wont open... van is only a week old!!
It can be set in the menu:
press menu and then the up-button a couple of times until you see the option 'RADIO OFF' and set it to 0 minutes or whatever number of minutes you want.
I have an 08 Doblo Dynamic with the Fiat 223 Blaupunkt Head Unit in it. I've tried all manner of holding the menu key, holding other buttons, pressing lots of combinations. Is it safe to assume that this unit just can't be operated via the ignition key? I've had the unit out and put my meter on the back and there is a switched live, but this unit just doesn't seem to want it use it! Anyone got it working?
