Yellowjellyfish
- Joined
- Nov 2, 2010
- Messages
- 45
- Points
- 5
Hi Everybody
i have a 2004 Ulysse which I have installed the electric sliding doors into from a donor car. i have 2 disabled children who struggle with closing the doors properly so electric was the way to go.
I have taken everything from the donor, installed it into my Ulysse, and have now got the system to a point where all the buttons inside the car trigger the 3 beep error.
Installed equipment-
Motors
Rear loom
Ecu
Hinges
Maxi fuses next to battery
Rear buttons
Roof mounted buttons
Motor and sensor and wiring inside each sliding door, including contact plates
I have converted the key fob from 2 button to 4, when the door button is pressed the car unlocks but nothing else.
The system has power enough to error, but that's it.
I know you need to initiate the system after battery disconnect, but can't do that until I can get the motors going.
Has anyone done this conversion? Do I need to change the steering wheel node aswell?
Any help would be appreciated, as going mad :bang:
Motors
Rear loom
Ecu
Hinges
Rear buttons
