jrwilshire2003
- Joined
- Jan 20, 2014
- Messages
- 11
- Points
- 2
Hi all,
New to the Fiat forum but have our first problem with our 500. Basically under load (when pulling away) or at extremely low revs or if you keep the handbrake on and try to pull away, there is a loud knocking noise coming from the left hand side of the car. I've ruled out suspension issues as it doesn't make any noise whilst driving along even when you hit large holes but under load and low revs it causes something to knock from the front left. Wasn't sure if it was some sort of engine mount had gone but its totally puzzling me.
Any help would be grateful!! Cheers!
P.s. also have a constant squeak coming form the right rear brake, Presume it's either holding on slightly or something is in there.
Cheers!
Cheers!
