Technical Fiat abarth 600 ( Replica )
diluppo
greetings friends
I have a fiat 600 which I have transformed into a replica of abarth 1000
I'll add some pictures of the products processing and would like your opinion on the matter
I live in Venezuela, I hope you like
thanks
This project I started in 2005 and today is almost finished
taking information about what was the car, I made a number of changes, ranging from the engine to the suspension, adding disc brakes on all four wheels with dual circuit hydraulic brake and clutch system, including replica made ​​in pantograph wiper
I must add that all the work done for me is made ​​by hand and in my small workshop at home
some pictures of the start of the project
Disarming the auto manufactures a support for working Body
will remove all the layers of paint and I leave the metal exposed and repaired damaged by rust all parts
more photos
after explaining the whole Body will apply a protective coating to the elements
JAYAAR thanks indeed is a complete restoration and is also the manufacture of a replica of the Abarth which replaced the small 633 cc engine and 21 hp for one of 70hp 1116c.c I add disc brakes on all four wheels, reformulated and manufactured the front axle independent suspension making
Thanks Bossy Rossy (y)
much rust bottom of the Body
parts were new
what engine have you installed,where did you get it and how hard was it to make it fit?
congrats on your nice project
philippe :)
Hi Philippe install engine is Fiat's 128 and VW transmission
I did a piece for the coupling
I first made the mold in thick paperboard
then I did wood
I finally did and iron
motor and coupled trasmision
amazing, looks really clean :D
i'm also looking into swapping the engine on my fiat 600. I feel it would be a lot more fun if it had more power the original engine has a real lack of it :) what type of vw transmission is this? and does it fit or do you need to make some adjustements to the body of the car?
thx for replying
philippe
hello friends
philippe:
Now the power of my new engine is 60 hp in exchange for 21 of the original motor. quite fun to have extra power
transmission is VW 1974 with axes gimbals which engages the wheels Fiat
some photos
VW shaft is cut and the work of the new spline is to use spreaders
on one end side vw transmission
and fiat wheel sideand fiat wheel side
Greetings friends
continuing the bodywork
Hoa Amigos
following work, repair the lower parts
