Fiat scudo 2006 keeps cutting out ....
centenary2003
My fiat scudo 2ltr jtd, has just cut out after starting it up, there was a whining noise to start with then it cut out .... had new alternator and timing belt fitted last week, its never ending, is it a fuel pump problem or sensor .... no lights on dashboard when it started either .... help. can anyone tell me where the fuel pump in the engine is ?? could it be a fuse problem ?? if so which fuse do i check ??
it could probably be down to the fuel pump had similar problems on a works truck and it's was due to the pump being clogged by bad diesel
