lilliehorn
I cleaned out the EGR valve of my 2.4 JTDM during the weekend due to the "insufficient flow" error code. It was really needed after more than 40.000 miles of operation. I also cleaned the MAP sensor according to the excellent instruction by Halilson. I refitted everything complete with a new bullet blanking plate as instructed. Afterwards the car runs almost in limp mode, no power at all below 3000 rpm's. No error codes are recorded. When I try to execute the "EGR valve solenoid test" with Multiecuscan I cannot hear anything from the valve. What has happened? Does a non working EGR valve make the care loose almost all power below 3000 rpm's? Or did I break the MAP sensor cleaning it? Doesn't that generate an error code? Please help .
