justinpburrell
- Joined
- Jul 29, 2013
- Messages
- 1
- Points
- 1
Hello..just bought a multipla..it has recently passed its MOT but I just checked the previous tests, should I worry about the following reasons that it failed?
Reason(s) for refusal to issue Certificate
Offside Stop lamp not working (1.2.1b)
Offside Rear Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Offside Front Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Offside Rear wheel arch Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Advisory Notice issued
Nearside Inner Front Tyre worn close to the legal limit (4.1.E.1)
Nearside Rear coil spring corroded (2.4.C.1b)
Offside Rear coil spring corroded (2.4.C.1b)
Nearside Rear Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Offside Rear Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
It did pass a week or so after this but Im still abit concerned, should I be?
