Nice easy one this
So the Engine Management Light (EML) aka Multifunction Indicator Lamp (MIL) / OBD light is on, Or you have FES/ MES and the leads and want to turn off the service indicator, Reset the Oil degradation counter, do a Proxy alignment or dabble with the other advanced functions........
You have all the leads / plugs/ computer but where is the Port.... :confused:
First open the little cubby by the drivers right knee......
and stick your fingers up the back of the fog light / menu switch array...
give it a good tug towards you...
Hinge it downwards
Locate the OBD2 plug and remove the cover you can see the OBD plug has a yellow band down its centre....
Then plug in your device ensuring it is the correct way round
Plug in your lead / adaptor and turn the ignition to MAR and follow the instructions that come with your chosen software / device...
  • Like
Reactions: varesecrazy
