:bang: Hi just taken a 2003 03 1.9 jtd doblo cargo it needed a new engine as bottom end no good due to cambelt failure, so sourced another engine and fitted today starts fine although alternator light and engine managmnet light on, ive got a spare alternator and so will fit that tommorow, lugged my scanner in and its riddled with fault codes and will only rev to 3,000 i cleared the codes and these codes below came straight back on, just wondered if anyone could give me a heads up as i think some may be the same problem.
The codes are p0101 air mass sensor circuit
p0380 plate heating thermostat relay
p0110 intake air temp sensor circuit
p0638 flow modification throttle
p0404 egr system
p0236 overboost valve circuit
p1612 fuel filter heating relay circuit
p0404 egr system
