keat63 Established member Joined Sep 25, 2012 Messages 761 Points 178 Location Leeds Jan 18, 2013 #1 My daughter has just bought a sub for her GP1.4 Sporting 2007. Before I start ripping it out, Does the standard B&M header unit have facility for low level output and a remote cable output.
Most Easterly Pandas Speed Reader of the Year! Parked in the garage Written a guide Joined Aug 15, 2007 Messages 44,236 Points 7,382 Location Norwich, Norfolk Jan 18, 2013 #2 Nope, B&M is a separate unit to the head unit
scout Big is not always better Parked in the garage Joined Nov 24, 2012 Messages 3,324 Points 905 Location Aylesbury Jan 18, 2013 #3 You may also find that it would be better to connect a sub and amp to a head unit, a header usually has an exhaust fitted to it :devil:
OP OP keat63 Established member Joined Sep 25, 2012 Messages 761 Points 178 Location Leeds Jan 19, 2013 #4 The sub has high level input, but i'd rather use the low level phono leads. It would have been esier and less messy. I'll wire the remote from the ignition, via switch also, and tap into the rear speakers then.
Most Easterly Pandas Speed Reader of the Year! Parked in the garage Written a guide Joined Aug 15, 2007 Messages 44,236 Points 7,382 Location Norwich, Norfolk Jan 19, 2013 #5 Probably easier, and safer, to tap the remote from cig lighter / power aux
