There should be some collar(s)? on the ARB which centre the ARB between the bushes, IIRC these are on the inside of the bushes.
Not unknown for the collars to come adrift, been mentioned before on here.
If this is the case, you could try a jubilee clip to hold the loose collar in situ, if that's not man enough then getting it properly welded on again is the way to go.
