I have a W Reg 1.2l Speedgear punto which I've spoken about before. Normally when I'm in traffic I shift from Drive to Neutral so theres no stress on the car.
Anyway the 'LCD' screen didn't show that the transmission was in "D" or "N" so when I shifted back into drive this warning light was flashing on the bottom left hand side of the dash. It sorta looks like a car boot which Ive googled and it seems to be 'Automatic Transmission Failure' warning light.
The car however, is still moving. I turned the engine off, and restarted it and it still appeared. When I got home I shifted into every option and the light disappeared just like that. Obviously it could have been an earthing fault (so i've read) maybe I'm not sure and I'm not 'that' technical but the car seems to be running fine.
Does anyone have an idea what this could be?
Also I have FES but which cable do I need to be able to read the fault code for it? I only have the cable to proxy align /edit odometer.
Thanks!
Thanks!
