Hi all and thanks in advance for your help. I own a 2005 Stilo Xbox edition which ive had since new. Ive had a long list of things done to the car (repairs not mods) but I like the car so I dont mind. The only thing is now, with money tighter than ever the car breaking down is totally unwelcome so I'm trying to self diagnose the problem so I can get the best quote on repair (if I cant repair it myself.) I have read a lot of posts over the last week and im now just re-reading stuff and not sure what to do so if you could advise me id be really grateful.
Recently I had a problem with a sensor which meant the car juddered whilst driving. It happened twice and then the engine management cut in so I got it reset and has been fince since. This may be unrelated I dont know? Then one morning I started the car as normal, and after the usual checks the battery light came on and the power steering wouldnt work, 30 seconds later light went off, steering worked and I went about my day. The following morning, same thing and on day three as I drove to work the light came back on and my car became as steerable as a train at 40 miles an hour for a frightening moment then off went the light. It then came off and on again and gradually more regular intervals as I got it home.
I have since found that, if I sit with the car at 4k revs for about 20 seconds then the light goes off (steering back) and if I drop the revs the light comes on.
I then wedged the accellerator, and let it stay like that for 10 mins. Took the gas off and the light stayed off, tried to drive down the road but only got 100 meteres. If I get the revs up though the light goes out.
Ive tested the earths as per deckchairs guide and they are good. Ive checked the d4 as per deckchairs guide and its dry dry with no signs of ever being wet.
The battery is 1 year old and isnt losing power. Alternator makes no odd noises, all belts tight.
I'm guessing I just need to go get a new alternator but is there anything else simple I can do here? And is the engine sensor fault possible related?
I got the codes at home from when that fault was reset if you need them but the mechanic said there was nothing unrelated to the sensor on there.
Thanks in advance for your help.
