General radio code
General radio code
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
If the display shows " WAIT ", it's because someone
has tried to enter a wrong code too many times.
You will need to leave the radio and ignition switched on until the display shows " CODE " then " - - - - ", then enter the correct code.
The amount of time you have to wait depends on how many times a wrong code has been tried, but could be up to 2 hours. Make sure your battery is OK if you're leaving the car stationary for the waiting time.
hallo Davrem, on february 2012 you send me code for my radio but doesnt work, i was waiting 5 months till today, and now i can try another code. can you send me? im donated member.
my numbers are :
BP 937213819175
RP NR 7649372316
PR NR 735272569
thank you
my numbers are :
BP 937213819175
RP NR 7649372316
PR NR 735272569
thank you
BP 937213819175 is the same serial number you posted in February. The code for it is still: 5334
If it doesn't work, either you are entering it incorrectly, or the EPROM inside the radio has been reprogrammed at a radio workshop.
