Hi all,
My Stilo has been timed up and is now running, but in limp mode.
It’s running poorly and the errors coming up are loose wiring alternator and all 4 injectors (according to the mechanic).
It’s been recommended by FF members to take the battery off and charge overnight as poor charge battery can give a multitude of ghost codes, put a little WD40 under the block and reset the ECU. I’ve told my mechanic to do this, and also check the crank sensor to make sure it’s working and not bent in any way.
Is there anything else I should be looking out for?
