So my cinq failed its emissions (1242 8v).. Results below.
Engine temperature 83.0°C
Fast Idle Test:
Engine Speed: 2450 – 2950 rpm - not checked
CO: max 0.300% 1.441 FAIL
HC: max 20ppm 60 PASS
Lambda: 0.97 – 1.03 0.979 PASS
Second Fast Idle Test:
CO: max 0.300% 2.515 FAIL
HC: max 20ppm 100 PASS
Lambda: 0.97 – 1.03 0.941 FAIL
Natural Idle Test:
Engine Speed: 750 - 950 rpm - not checked
CO: max 0.500% 0.404 PASS
Now, not really sure what to do about this other than give the car a good thrash on the way there. Oil & filter are good, air filter is clean, exhaust is ok. Car runs perfect. Thought i would turn down fuel pressure but then thought thats not gonna do anything is it on an injection car? I was thinking if i restrict the amount of air getting through the air filter would that result in ecu chucking in less fuel and thus bringing it down a tad.
Car has quite old petrol in it (with some injector cleaner in it), would that effect the emissions at all?
I just noticed that its down on the test sheet as 1108 not a 1242, would the limits be any different?
Got til Wednesday to sort it - chuck me some opinions.
edit: car has been sat for approx 3 years, i did do about 10 miles thrash on way to MOT.
Fast Idle Test:
Natural Idle Test:
