MarkoDoblo
- Joined
- Feb 6, 2012
- Messages
- 2
- Points
- 1
Hi guys,
I am new to this forum and came across while searching how to solve the heater problem that i have in my Doblo 1.4 (2006-2009 model).
It stopped suddenly one day with no previous signs of malfunctioning. The fan doesn't start but also the heater i think it doesn't work because as i remember when the settings are on "full hot" (all the way to the right) and speed even on 0, i could still get some heat blowing slowly unless i close the air circulation on internal only.
Now my first thought is that some fuse is broken, but as i see on some diagrams most of the fuses related to the heating system are MAXI Fuses and in the manual it says that you shouldn't change those yourself. Does anyone know why? Anyway i still have to check all the normal fuses because on different pictures i find different fuses related to heating system.
I was wondering if someone had the same problem and solved it by changing a fuse, or otherwise???? What else could it be??? Should i try to find a new Maxi Fuse and change it myself???
