cmm.sedici
Ok one more problem that i'm enjoying at the moment...!
The brake booster has started to hiss when the engine is on. Through some interweb research it seems that there's a rubber o-ring that is prone to failing which means the brake booster (which forms a vacuum seal) no longer is forming a decent vacuum.
So options at the moment are to suss out how to remove this o-ring and replace it myself (messing around with brakes (not keen), finding a decent garage that will do the job, or just getting the booster replaced.
Any of you had a similar problem?
