Hi ive got a corsa 1.3 cdti, yes in know this is a fiat forum , but i believe they both use the same engine
Im basically after some help, im having intermittent starting problems for my cdti;
* when cold it doesnt always start 1st time, it runs rough like its not running on all 4 and , if i hold the revs at 1500rpm there is loads of white smoke and vibration. Fine once its warmed up. Then sometimes ive driven for 30 mins and left the car for 15 mins and it struggles starting, just turning over for about 5-10 secs and sounds rough. this is totally random too!
* i get an occasional/ hesitation.misfire when driving, this is totally random, it can happen once then not again for weeks (usually when ive got low fuel) , it can also do it all thru a journey, or as mentioned just a one off.
had the codes read when it first started happening were; low pressure on the rail, glow plug curcit open and fuel system malfunction. These have been cleared and no more codes have ever come up!
Ive had the following components replaced; EGR, in tank fuel pump and fuel filter.
im going mad here, any ideas? pls
glow plugs?
glow plugs?
