Technical rear window washer stopped working
Birkenhead
as title says. i have a 06 punto grande thingy, and the rear washer has stopped working. theres no sound or anything.
the front washer works, and i cant see it being the motor, so im thinking fuse maybe? unless they run off the same fuse(like my 306)
the wiper motor still works btw
My first thought was the hose connecting to the rear washer had disconnected somewhere.
Might be worth a look checking where the hose has it's connections first to see if it has come loose.
In the times I've seen this happen it has been the hose come loose.
It's strange that it does not work at all, as both are fed from the same pump literally just different lines. Does the pump make any noise then you try to use the rear washer?
hey again sorry i just realised i posted this in the abarth section :s sorry
anyway, there is no sound from the motor when i do the back wash, the wiper doesnt even move, but i can turn on the wiper and when i select reverse the wiper also goes. if it was a loose hose, wouldnt i still hear the motor goin?
