Technical interior light fuse??
does any one know where the interior light fuse is dont want to pull all them out to find the broken one is it under the bonnet or in the glove box??:confused:
In the glove box, Behind the USB on the left.
You have to undo the bolt holding it on then just move it to the side.
Its the top one on the right. 7.5Amp :D
My interior light has stopped working and so has the boot light. Replaced the fuse 10AMP which was blown however that hasn't fixed it.. As handbook said it was a 10AMP fuse.. However will check the 7.5 Amp as stated above.
Thanks for the tip hopefully it is just that fuse. :rolleyes:
