frankp
Hiya
I seem to have a little problem with removing the front wiper motor on my G-reg fiorino.I am able to access the unit,can undo everything I need to but seem to struggle with the centre nut.As soon as I try to loosen it it seems as if the outer (through which the bolt comes out for the wiper arm) 'sleeve' seems to turn too.is there another nut under the panel that's not visible from the outside or do I just have to grind it off?Any advice would be appreciated.Thanks
