General help needed!!
ollyh83
I have an fiat ducato swb '07 plate' van which i am converting into a camper van, I have removed the factory fitted bulkhead, which i now need to cover where it bolted, I have seen in pictures that the minibus version has trim panels instead of the bulk head, i cant seem to locate any of these panels anywhere any help or a nudge in the right direction would be very gratefully received.
many thanks olly
Not sure what you're lining the van with but I also needed these pieces.These can be found on factory conversions so maybe if you contacted one of these companies they might steer you right.I taped off the gaps and filled with expanding foam then covered the lot with the van lining felt I was covering the inside with.
Your best bet would be to join the Self Build Motor Caravan Club (SBMCC). There will be lots of help and advice and you get discounts on various parts.
