Ok, so I have been experiencing some resistance in the wheel when steering to the right but not the left for some time. While researching the issue online the question of power steering fluid change popped out. Apparently there is no set recommended time or mileage limit but this is one of the most overlooked essential fluids in the car (along with tranny oil). Now, the recommended fluid is the Tutela GI/R which is a bit harder to find but I located it @ 14eur a liter (which is 300% more expensive than the older Tutela GI/E (dextron III equiv.). Capacity is 0.7L but one needs considerably more in order to get all the old fluid out of the system if doing it manually.
In my car the fluid is totally black with a chemical but not burnt smell. This tells me that either it was red when new (GI/E) and turned black from age because it was never changed since 10/05 OR it was replaced @ some point with some Dextron II/III equivalent. The reccomended GI/R is green in color.
So can someone look in their's over the weekend and let everyone know the color and condition of PS fluid? It is in the white bottle with a black cap in the back of the engine to the left side (at least is so on LHD). The system is of course totally GM so I am tempted to go with Dextron III being cheaper and needing a lot to manually recirculate all the old fluid out. I'm just not sure which way to go until I here from someone else. Changing can't hurt (other than the wallet) but might help with the instant locking of the wheel. Thanks!
