Hi
This is quite a common question that unfortunately has gone unanswered. I cant say for definate this will work, but in logic, it should.
Connect your aftermarket amp up using the rear speaker outputs from the stereo (like in the punto's active sub) if there are no RCA outputs. Now from here you have 2 options... You can get an amp that has high speaker level inputs (therefor all you do is have to run the wire in) or get an RCA convertor whereby it turns the speaker level input to a levelled RCA output. From then you can connect up the amp as normal.
If anyone can think of another way...
