JTD Monkey
My JTD has gone in for a service and I have been given a multijet (1.3 16v 70bhp) as a courtesy car. An ideal opportunity to see the advances in diesel technology. So far I have noted;
All in all, more refined for sure but if I was trading in a JTD ELX for a multijet Dynamic (an apparent replacement) I would be less then chuffed. the 1.3 16v 90bhp model (when it comes out) will undoubtably answer the performance short-fall, but I can't see it resolving any of the other problems with 'turbo-lag' potentially being worse
- The multijet is much quieter at idle with no vibrations through the car at all. There is a gentle 'hum' in the distance but it is not unpleasent. The JTD betrays its diesel roots at idle.
The clutch in the multijet is much lighter and it feel like a petrol cars (i.e. no vibration). The JTD clutch has always been a bit 'agricultural'.
However
It sounds like a moronic cow when you accelerate. It is most off-putting.
The turbo is like a 'switch' with huge-lag. At about 1800rpm it suddenly wakes up, or about 1 second after hitting the throttle when cruising. It can be fun the first few times, but gets tiresome very quickly and makes smooth driving a pain. The JTD has power at all times.
The turbo lag is a pain on hills. On the A1M I found myself loosing speed when I came to an incline, having to bury the throttle to keep up with traffic. The JTD never has a lag problem and laughs at inclines.
The JTD will crawl in traffic with no contact on the throttle, the multijet went into 'spasm' when I tried this and nearly stalled.
I did not expect performance to be as good as the JTD (down on power and torque although it is about 100kg lighter) but I found it really wanting for performance and not a patch on the JTD (the car has 6000 miles on the clock so it may need a little more time to loosen-up but it won't make that much difference)
The economy of the multijet (on the basis of the trip computer) seems little different to the JTD
