Hi,haven't got a picture,can get you one if required,but easy to find. On the back of the inlet manifold,roughly in the centre you'll find it small black block,connector plug on top and secured with one bolt,usually a torx or ribe bit,usually electrical connector has a yellow tag to pull out first before you can release clip.
When removed make sure where it enters the manifold is clear/clean,as there can be a build up of oil/etc here,hope this helps,if you can't find it I will get a pix with my phone,John.
