Technical How to fit a new starter motor on a fiat ducato maxi 3.0 160 2007, HELP !!!
Whitevanman2011
has anyone got a clue how to fit a new starter motor to a fiat ducato 160 multijet 2007 3.0 litre. ?? pictures would be handy if you've got them
Turn the ignition key to the OFF position. & remove Key
- Disconnect the negative battery terminal - this will lose the radio code which will have to be re-entered with the correct code pin from the code card for your vehicle after the refitting the "new" starter motor & after the battery is reconnected.
Raise the vehicle if necessary
1. Lift up protective cover (1a), undo cable terminal retaining bolts (1b) and disconnect starter supply cables from their terminal bolts(1c).
1. Undo the 3 starter retaining bolts and remove the starter motor from the engine bearing in mind it does weigh quite a bit so be ready to take the weight when the last bolt is removed.
Reversal of above procedure for refitting.
