General Ahhhhhhh Boost Leak
Sunderland
Hi all,
Got a Dam boost leak somewhere and i do not no where to start:bang::bang::bang: .
Just can hear it hissing :bang::bang::bang:
Please Please help my heads in bits:bang::bang:
Don't get worked up about it, They're not hard to fix. Just take your time removing each hose you can and checking it for a split. Sometimes just putting them back on again nice and tight fixes them.
Cheers M8
Sorted now it was the T Peice which i put in for my boost gauge i never took the little brass bit out of 1 of the ends..!!!!:rolleyes::rolleyes::rolleyes::rolleyes::rolleyes:
hiya just a quick question, that little brass bit in the t piece, is there not supposed to be one on the exit that leads to guage, mine has that with a little hole in it. boosts fine up to 10 psi and thats all you get to red line, if you absolutely floor it in 3rd then the boost kicks to 15 psi but thats it, conversion is around 1 bar maximum all in,, and 10 psi normal boost driving hard, around 0.6 bar,,,,,,,why isnt it boosting right?
