Technical Doblo 1.3 Diesel excessive white smoke.
CMH1967
Hi, i have a 2006 1.3 multijet diesel doblo. Over a pretty short period it starting running roughly and bellowing loads of white smoke out the exhaust. I took it to a diesel injection specialist for the injectors checking, the injectors have tested ok . Any ideas what i could be looking at ??
usually white smoke is a sign of condensation water
could be water in diesel
i know thats usual symptom
black smoke sign of overfuelling
Coolant getting into the pots?
Had this one before and the head gasket looked OK but the new gasket worked a treat. I was lucky because one of the caps on my eezi-bleed kit fit the expansion tank so I could put a bit of pressure into the tank - which pushed coolant out.
As above, sounds like it might be the turbo seals. Unless the car has been run hot there should be nothing wrong with the head.
Pump and injector problems would usually give bad starting too.
could it be oil cooler any oil in coolant
hi i had the same problem with my 1.3 multijet mpv diesel last christmas the problem was the glow plugs, one had cause damage to the relay system, had to have a new glow plug and a new electronic control fitted cost £170 plus labour at fiat garage hope this is of help to you .
