General How To Put Microwave In Doblo Cargo
Garuff
Hi, i really want to install a microwave in my doblo, sucked off with sarnies every day and could really do with a warm meal when i'm in work.
cheap and easy way if possible..
I got two sockets in the front one ciggy and another one? whats that for?
Thanks guys.
Thanks guys.
Hey Garuff
Ive had a look around and it seem there is not an easy or cheap way of putting a conventional microwave in a car.
http://answers.edmunds.com/question-can-i-buy-an-inverter-to-power-a-microwave-in-the-car-574.aspx
But their is a American company that is selling a portable microwave oven, but again I expect their not going to be cheap and their in such high demand that it looks like they out of stock so buying one might be difficult
http://www.thewavebox.co.uk/
Independent review: http://www.autoblog.com/2007/03/12/crave-a-hot-pocket-plug-the-wave-box-into-your-dash/
May I suggest camping equipment instead like a camping stove as it looks like the cheapest and easiest option and I've heard truckers use them as they don't have any equipment in the truck to cook food.
There's a range of products here http://www.towsure.com/
but you wouldn't be able to use it in the car for the risk of setting the car and yourself on fire.
Hope this helps =]
Orey
700 watt inverter is not going to power a microwave the load of the microwave is to great for the inverter to handle and it would just blow it to pieces and could damage the car electrics, maybe a TV and a PS2 would work but not a microwave.
You would need at least a 1500-2500 watt inverter to safely power a microwave in the car and those inverters are well over 500 quid.
The power requirements make this a non-starter, I'm afraid. 1500W @ 12V equates to 120 amps - think about the cabling you'd need to carry this sort of current, and then think about what it'd do to your battery....
How about getting one of these?
http://www.surplusandoutdoors.com/s...s/camping-gaz-single-burner-stove-309376.html
Despite the obvious safety warnings, I used one in a Rascal Van for 20 years without setting anything on fire or blowing myself up.
Thanks guys! might just try and get a camp stove thing.
gas stove should be ok in back off van when on shouldn't it,i'd have the doors open and a fire extinguisher handy.
what about a toaster? cpould i wire one up so it fits in ciggy lighter?
As a TV engineer to trade and loads of years with car electrics I can assure you are wasting your time, I have a 12volt kettle that is rated at 120 watts (10amps) and it takes 50+ minutes to boil 1 litre of water and that is with the engine running and the battery over 13v.
A 700 watt microwave employs a half wave rectifier to give the magnetron its 2000v approx to operate this chops up the AC waveform and will blow 90% of inverters on the market.
A toaster needs 1000-1500 watts so a 2KW inverter would be needed, totally impractical for a small car with a tiny battery.
Forget it or put your cold pies and bread on the exhaust, or head to McDonalds! :D
Brad you are dicing with death for your Plasma & Playstation. Most inverters on the market do not supply a clean sine wave (even if they tell you that they are pure sine wave, have a look at the output on a scope) The SMPS power supplies these sets have do not like the rubbish from these inverters and will fail prematurely!
Hey Garuff
If your thinking of getting a camping gas stove then try one of theses it fit directly on top the the stove
http://cgi.ebay.co.uk/New-4-Slice-F...Supplies_ET&hash=item2eaef2e5be#ht_2303wt_698 as this is the cheapest option
There is an in-car toasted sandwich maker that I've found on the net
http://www.roadpro.co.uk/retail/product_detail.aspx?prod=12V+Toasted+Sandwich+Maker&id=85
how it would work effectively and if it is reliable and safe to use in the car is another question though
hope this helps =]
Orey
How about a really cheapo microwave (tesco value/student range) and a cheapo generator?
Alternatively, if you are within 50 metres of a power outlet, why not buy a long extension lead & ask if you can plug in to charge your battery. Tell them that a 10 minute charge will be enough to start the car tonight :devil:
(and the beeps are to let you know the charger has worked)
My parents bought a 12v kettle to take when they went on a picnic to save carrying a flask of hot water - they assumed it would boil their water.
Two cupfuls of water took over an hour to come to a mild boil & that was with the engine running.
The next time they tried it, they plugged it in when they set off & it still hadn't boiled by the time they got to their picnic spot.
After that, they left the kettle in the bin where it belonged.
Looking at the link above even this site specifies the use of a 1200w inverter, again totally impractical for use in a car, a 75AH battery would drop below 11v very quickly and the inverter would shut down. Remember a 500w microwave is not that efficient and would be drawing much more than it's 500w output.
The one on sale above is for use with a mains electrical supply on a campsite.
