Newbie posting. I have a 2006 1.9 MJT (120hp) diesel Doblo with 100,000km on the clock. The engine light has come on and according to my local Fiat garage it is coming from the DPF (built in particle filter) which is clogged. Mechanic has reset the light and says I should run the car in fourth gear on the motorway at high speed to try to clean the DPF.
Has anyone else had this problem? If yes, how did you fix it?
I only recently got this car and have done 700km in it so far - mostly urban driving at low speeds (<70km/hr).
