Technical Rear brake drum nut
Worsley, Manchester
Hello does anyone know the size of socket needed for the nut on the rear brake drums on a 1.4 8v, as my grande failed its 1st mot this afternoon on 4 problems, back brakes/handbrake being one of them, was advised the shoes need replacing, or cable needs tighting up.
Any help will be much appreciated.
I dont think you need to remove the hub nut :confused:
I "think" that you just have to remove the 2x torx bolts then the outer drum slides off over the shoes
no doubt someone will be on soon with the answer
what exactly did it fail on Handbrake efficiency?
Yeah something about handbrake efficiency, and no reserve.
I did try and take the drums off about 8 weeks ago to find out they squeak when i release the handbrake or brake pedal, but could not get them off.
And a glass hammer...
