Hi, I have got a 57 plate xlwb ducato maxi and a few weeks ago I lost all pressure in the clutch pedal. After taking it to the dealers(waste of time, but that's another story) I had it repaired at a local garage. They replaced the full clutch and the cylinder that is inside the gear box and I thought that my problems were solved. However a week later the clutch pedal started to sink to the floor on its own when I was applying the brakes and I was having to pop it back up by putting my foot underneath the pedal and manually flicking it up. The garage then replaced the cylinder behind the clutch pedal in the cab and lo and behold 5 days later the clutch is sinking to the floor when pressing the brake pedal!! I am not leaking brake fluid and the brakes have been re-bled and I am now at a total loss as to what to do. I have just started my own business and this van is my livelihood, any help here would be very much appreciated.
By the way, the van has only covered a touch over 24,000 miles!!!
