the coke cany ou found under the auti is the petrol filter (probably).
You were looking for the crash switch, it is under the radio consol forward of the gear stick where the bulk head raises from the floor.
But there is no point in pushing the crash button if you can hear the fuel pump prime, the 2-3 seconds faint whirr when you turn the key.
The 'carb' is an injector which is opened by the computer electrically, the pump pressurises the petrol, so when the injector is told to open the petrol squirts out. The injector does have a pipe connected to it but you dont need to take it off you need to remove the air cleaner element and sniff there will be a smell of petrol, if the computer is telling the injector to open and the injector is not broke.
The earlier post asks that you confirm you have a spark at the plug lead ends, please try that if you can smell petrol.
If you cant smell petrol are there any other warning lights on?
Please dont tell me/us you can remove hoses, otherwise we will ask you to stand under the garden hose with the water turned on... That is not dangerous
Noel
P.S. I think there is a return hose to the tank, which should flow petrol, when you crank the engine, but dont remove this. If you can see petrol on the butterfly or small it there is petrol being injected...
