General Electric Panda
Hampshire
What would it take to make a panda run on electricity? the obvious are:
A donor panda(selecta would be the easiest i assume)
A motor (very big one)
Lots of Batteries
But how would you "fuel" the panda? Plug in points or have a way of producing electricity on board?
You could use alternators on drive shafts (obviously with no engine there isnt a drive belt to power it. replace the sun roof with a solar panel. have miniture wind turbines stuck on the roof and bonnet.
Personally not a fan of plugging a car into a wall as this defys the point of not trunning on Petrol.
How do you know a car is more economical when running on electricity? obvoiusly you can't meausre MPG with elecricity. but cost aswell. We might have to imagine that electricity is "free". would the cost of a conversion be less than the running of a panda around town for 6months. (similar to converting to LPG really).
car electrics would be a trouble to, as i understand the selecta has all different types of sensors on the engine and ecu to control the box.
Jon or Petel your Selecta knowledge would be much appreciated here.
This is something i would be quite interested in trying if easy enough to do. so all help much appreciated.
Plug in and recharge is the only real viable way tbh.
Quite so, unless you can overcome the laws of physics.
Running an electric motor from an alternator (mounted on the drive shaft or anywhere else) will never work because you need to put more energy into it than it can create.
Hydrogen fuel cells will be the way to go in a few years time.
Dave.
Just to add my bit to this,
Electric cars are definately more energy efficient than petrol, and even more so are hydrogen fuel cells. To produce the hydrogen, it is true large amounts of electricty are needed for electrolysis, but they can use power stations that run at typical efficiencies of 80-90% where as your petrol or diesel will be lucky to achieve 40-50% efficiency when converting the energy in fuel into movement.
Personally though, the electric car is completely impractical due to their limited range and performance. Does anyone know the range of these electric panda's? Cant seem to find any information of its performace on the net.
Would be cool to see a genuine Panda electra though, anyone going to import then? :p:devil:
Si
Not such a long way off perhaps? I hope they're not anyway, I've got shares in a company called Ceres Power Holdings that make fuel cells.
Dave.
Detail from the eBay ad:
Seit 1988 gibt es den Fiat Panda Elettra mit Elektroantrieb, Gleichstrommotor bei 12V und Viergang-Schaltung. 2-Sitzer mit 9,2 kW (13 PS) bei 2500 U/min. Max. 80 km/h und einer Reichweite von ca. +/-80 km. Von 0 auf 50 km/h in 20 sek. 12x 6V Bleibatterien (350 kg). 8h Ladezeit.
So it's a 2 seater (batteries in the rear seat area and load bay.. no luggage room). 13 HP :eek: 50 MPH flat out and approx 50 mile range. 0-30 MPH in 20 seconds!! :slayer: 350 Kg of batteries (total kerb weight was over 1100Kg).
From another site, I found out the list price of a Panda Dance (903) in Germany was 11,000 DM. The Panda Elettra was 37,000 DM :eek::eek::eek:.
No wonder it was never a big seller....
Cheers,
Plug
I am interested in exploring an electric motor conversion for my 4x4 Sisley.
Has anyone done this with recent technology?
Ideally I'd like a DIY kit to install, but that might be too optimistic.
if you have the money, anything is possible. modern day brushless DC motors would make light work of pushing a panda.
i had a blue 4x4 sisley that sadly ended up being far too rusty to save. i never made it public but my plan with that would it have been a OK car was to make it a hybrid.
rotate the rear axle 90 degrease so it was pointing strait up and fix a large brushless DC motor to it. i already had the motor, i just needed to make a decent controller for it. then decide what voltage i was going to run it at. i had half built the controller deciding that i was going to run the system at 96v however it would have had the ability to handle 120v with ease.
the motor would have come up through the floor and have a box around it held in place with clips with a seal around its base to make it air and water tight while still allowing suspension travel.
i was going to use AGM cells with the future idea to upgrade to the block style Li-Po cells as the main power.
i had a lot of the stuff to do it as i work in a scrap yard. sadly most of the stuff was sold on when i found the car was too rusty to save.
Thanks for the feedback (and the YouTube videos, which have been very useful in the past).
Having owned the Panda for over a year, and used it daily for a 15mile run at altitudes between 700m and 2000m for a winter (in Alps), with Cervina Snow tyres, I found a little bit more power would be nice.
Rather than swapping out the engine for a later panda or another, like you mentioned, a brushless motor and used Tesla battery(s) looks possible as I see lots of similar conversions for other cars in kit form.
I'd like to able to retain the gearbox,and the 4x4 capability. And because the daily drive is all downhill braking, having brake regen would be advantageous.
I haven't been able to find any detailed specs on the Garage Italia Panda unfortunately, as this is the only recent conversion I have seen.
More research required on my part
one method i thought of doing to retain the 4x4 ability was to quite literally build the motor directly to the rear diff. making it so that the prop shaft went through the motor.
at the time i was very much into "eco modding" and really wanted to have an electronic brake rather than engine braking. my plan was to have a (please dont laugh) throttle thumb grip on the gear stick. when i press the brake pedal so the brake lights come on it enables the thumb throttle. rather than pressing the brake pedal down more to slow down, i was going to have it so i pressed the thumb grip more.
the thumb grip dumping the generated power into capacitor banks or batteries.
stripping down large UPS'es from work i am able to get hold of loads of 240v DC capacitors that would work great as a bank for charging then feeding into cells. or directly tapping into as a kind of "kick down" for short bursts of power.
my head was a wash with ideas at the time. if i had not many projects like i have now i would still be tempted with the hybrid electric panda conversion given i was able to get one structurally sound with no rust.
my all time dream would be to do it with a car from the 1920s. keep it looking totally original from the outside but under it all is a vehicle that is capable of doing the UKs speed limits while being modern day safe to drive.
i am quite sure that if i had money, i would have already made automotive history.
There is an Italian company doing all electric conversion to old 500
But it’s 25k
[emoji33][emoji33]
Ian also interested in doing this. kits are way to expensive there are a few cheap motor options like modified forklift motor and Prius transaxles. but i haven't seen any cheep way to get decent battery capacity, could spend 4 grand on decent battery or by a 2nd hand leaf for thew same price. this guy has a lot of info on youtube
https://www.youtube.com/watch?v=i02c6DHMrpg
i am not really enjoying my 999 fire engine much thease days. don't know wether ill fix it, go electric or a 1.2 punto engine which i haven't got or a Peugeot 1.4 tud which i have got.
