Main problem is that the holes are the wrong way around. or am i wrong? the plastic clips from the strut should go in the small holes in the brace, right? and the bolts in the bigger holes.
well no matter what i've tried i can't managed to turn it around so the holes line up with the right sized holes on the car.
also the brake fluid reservoir is in the way... do you have to bend the bracket?
