Hi I've got a 2001 1.2 8 valve punto and I've had an oil leak from the rocker cover gasket I've changed it twice and it's still leaking any ideas Please
Try this stuff mate Threebond liquid engine gasket 1194
I just did mine today funny enough but the sealant I got was from a Vauxhall garage. Same stuff but on a small mastic type tube. Really good stuff mate, its what you want
Just make sure the surfaces are clean as you can get them thats all. I used it on all sorts and even the Vauxhall guy today said they use it where no sump gasket is fitted on Izuzu engines.
Its a little pricey but it goes a long way and is perfect for the job no question.
