General top steering column bearing/bush
wilmslow, cheshire
got some play in top steering column bearing, looking on eper its described as a "resiliant bush", see pic below
is this a fiat dealer part? are the prices on eper the actual prices?
is it hard to replace?
its a mk1 1998, no power steering
If you've access to a lathe and are happy to estimate the tolerances, you can almost certainly make them up. Otherwise, it'll be a FIAT only part.
Never done it, but I suspect you drift them out from the opposite side, press back in.
AFAIK, ePER is accurate if it's an on line version: you might try Fluffy the Impaler or Shop4Parts.
